This command enables or disables use of multi-topology TLVs as specified in draft-ietf-isis-wg-multi-topology-11.
| area_name | Specifies the router process to be configured. |
| single | Specifies a single topology, where extended TLVs are used in SPF calculation and TLVs. |
| multi | Specifies a multi topology, where only the multi-topology TLVs are used in SPF calculation and TLVs. |
| transition | Specifies a transition topology, where both extended and multi-topology TLVs are used in SPF calculation and TLVs. The transition option is useful when migrating a routing domain. |
| level | For L1/L2 routers, this applies the configuration to IS-IS level 1 or level 2. If the level option is not specified, the configuration applies to both L1 and L2 areas. This option has no affect on L1-only and L2-only routers. |
Single.
Multi-topology capability is desirable if both an IPv4 topology and an IPv6 topology exist with different routing paths.
Extreme supports MT IDs 0 and 2 (IPv4 unicast and IPv6 unicast) only.
The following command configures the transition topology mode for areax:
configure isis area areax topology-mode transition
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
